Cover art was applied to some of my MP3s using Mp3tag (which is an awesome program by the way, God bless you). However, when I play those MP3s in WMP11 is it not shown. Am I am doing something wrong, or is it a problem with the program?
Thank you very much for your great work. (And sorry for my bad German, otherwise I would post in German to make it a little eaiser for you.)
AFAIK, WMP11 doesn't support ID3v2.4 tags. Please change the tag writing options to ID3v2.3 at Options > Tags > Mpeg and re-save the tags. If this doesn't work, you might also try to remove the files from the media library and add them again.
