when I went to get tags from discogs mp3 tag wouldn't let me.
I made sure to enter the application code into the dialog box and it took it, then I went to get tags after that and it has a 401 error; unauthorized.
I just upgraded to the latest version.
Check out the advice in this thread and see if it helps.
/t/16278/1
I cannot see a bug here.
I tried it and it's intermittent... sometimes has the error and sometimes not.
So, if it works sometimes and sometimes it does not - what has changed in the meantime?
If nothing has changed on the MP3tag side - where do you see the bug in MP3tag?
If you have changed something with mp3tag - does it work again, if you change it back?
Is it reproduceable with a certain set of data?
Does it depend on the daytime?
ohrenkino:
it does it when I have any special characters in search now.
You might want to see this thread
/t/16121/1
further down (post #8 ) where something is advised about the search separator.
Florian
Closed
December 28, 2018, 2:36pm
7
