[X] Display of post-terminator chars non-complies with ID3 V2.3
1 Ensure Options, Tags, Mpeg, Read, [X] ID3v2
2 Load an MP3 file having a ID3v2.3 text frame having post-terminator characters e.g. bbb
3 In the tag panel, inspect Artist
Expected: aaa
Observed: aaa\\bbb
This is a failure to comply with the spec: http://www.id3.org/d3v2.3.0 says
4.2. Text information frames
... If the textstring is followed by a termination
($00 (00)) all the following information
should be ignored and not be displayed.
4.2.1. Text information frames - details
TPE1
This different interpretation of the specification is intended. There are two many files and programs out there, that treat the separator as in ID3v2.4 so if Mp3tag would do differently, there would be a lot more reports than those few which point to the misinterpretation of the spec.
I think it simply doesn't hurt to interpret it in this way.
I mark it as [X] where it means "Won't Fix" this time.
This is not a different interpretation of "the following information should be ignored and not be displayed". This is just failing to comply.
I mark it as where it means "Won't Fix" this time.
OK! :slight_smile:
