To reproduce this behaviour, do the following steps:
Mark some files in the file list
Press Alt-T for Tags
Press the 'add cover' button
Type two or three leading characters (from your files in the actual directory) in the filename-dropdownbox
(Example: if you have "ABBA - Filename.mp3" in your directory, type 'abb')
You will see a list with all the files beginning with this characters in the dropdownbox -
Now change the directory (one level up) by pressing the the yellow button right from your 'search in-' dropdownbox (the one with the green up-arrow)
Repeat step 3.) by typing again the same characters
Result:
The dropdownbox is still filled with the same filenames from 3.)
Desired result:
The dropdownbox should be refreshed with the content of the actual directory.
I found this behaviour, because all my covers are saved in the same directory - not together with the songs:
C:\temp\songs <--- all the covers
C:\temp\songs\abba
C:\temp\songs\beta
This is the reason why I have to change the directory (4.) to add the matching cover for the tagged songs.
