Hi, I really appreciate this program is able to display even korean language in the main panel with file list. But I found out, that korean language is not properly displayed in Tag Panel where I want to edit song's name etc.
I suppose it's just a small problem with encoding settings and hope it can be solved easily. Otherwise support for minority encoding in file list is almost useless when you can't work with it.
Thanks for your work and keep up!
