Hello,
I've been using MP3Tags for a couple weeks now and like it alot. But, I'm having a problem getting BB Code to export properly.
When the file exports, the BB Code disappears. I'm thinking the problem is with [brackets]. If I take the brackets out and just leave the text, it exports just fine, but then I have to go back and manually type in the []. Since I'm exporting as a .txt file, there shouldn't be a problem.
Is there some way to get around this?
I'm enclosing the content of the MTE file so you get an ideal of what I mean.
Thanks for any help provided.
$filename(%_folderpath%%_directory% (%Year%)forum.txt)%Artist% - %Album% (%Year%)
Artist/Band:............ %Artist%
Album:.................. %Album%
Release Year:........... %Year%
Genre:.................. %Genre%
codec:.................. %_codec%
Tags:................... %_tag%
Total Files:............ %_total_files%
Total Run Time:......... %_total_time2%
Download Size:.......... %_total_size% Plus .JPG and/or .PNG Files
Bit Rate:............... %_VBR% (192 kbps is CD Quality)
Album Art:.............. Yes
NFO File:............... Yes
$loop(%_filename_ext%)%track% - %title% - %_length% - %_file_size% - %_bitrate%Kbps
$loopend()
%Artist%, %Genre%, %subgenre%
