I am using 2.39p and after deleting some Extended Tags in a list with 30+ Extended Tags, it switches back to the very start of the list after each Action.
I know you can use Ctrl and Click to choose the tags, but this problem doesn't occur on files with so many tags.
can you provide step-by-step instructions for reproducing this issue? In my test cases, always the next tag field gets selected after removing a field.
this is not a bug, i am sorry for the confusion. I Just dragged the Extended Tags Screen to make it bigger and then it doesn't reset back to the first entry anymore
