mawi
1
Despite leaving the checkbox in options unchecked for "not updating file date time" - the modification time for the files are not updated.
The reason this is useful is for scanners and other software that checks if anything has happened / has been updated.
Thanks for a great piece of software.
/marcus
Can you please tell me which file type (e.g., MP3, FLAC, ...) this is happening with and which function (e.g., Save, Remove, ...) you've applied?
Marked as No Bug due to lack of feedback from the OP.
Florian
Closed
4
