Select a file or multiple files then right click select detele, MP3Tag remove file from the current listing as if they were being deleted but the file / files are actually untouch, refresh the file list or use file manage to check the directory those file / files are still there, no delete action being taken. How come no one found such a simple bug?
You have to press the [Ctrl] key to delete it permanently.
Oh, can't find in the document, yes, it works!
