I have added %_file_mod_datetime% to the view. The display format on my machine is mm/dd/yyyy hh:mm AM/PM. When I choose to sort on that column it appears to sort as a string with 2:08PM sorting before 7:11AM.
I will write a function to correct this, but figured you might consider it a bug. I figure I may need to take the year into account as well.
