In columns, export scripts and format strings, _FILENAME represents the base filename (no extension) as expected but in filter and actions, it represents the filename including extension i.e. what elsewhere is _FILENAME_EXT.
[X] _FILENAME can include extension
chrisjj
#3
It's a feature and since _FILENAME is not %_filename%, I'd not consider this as a bug.
Well, if it is deliberate, I cannot see the point of two different fields having the same name and the same field having two different names.
Anyway, I suggest since _FILENAME is undocumented in Help (as far as I can see), it would be useful to add a mention of this.
Florian
closed
#7
