[X] Filename Sorting Bug
I get to try this software and i love it.
But there a bug that it shouldn't happen, It can not sort filename properly.
I spotted this problem when i do with thousand of files named by random naming.
Please fix it. thanks
You have to be a little more specific.
What kind of sorting do you expect?
Where do you see files that are not sorted the way you expected?
Is there a pattern of files that are not sorted the way you think they should?
Because, quite honestly, my files are all sorted as I expected.
