[X] folder dialogs freezing
#1
I updated to windows 10 creators edition, and now all of the dialog popup's are freezing, they all used to work fine in windows 10 version 1511
#2
Works fine with my creators version of W10.
Havew you changed the way to install MP3tag (from local to portable or vice versa)?
If so: do you have sufficient access rights for the installation folder and all the other possible locations (see here for options: /t/964/1 )
Have you tried to rename the file mp3tag.cfg and start MP3tag with a fresh configuration?
This is what I would check right now.
#3
I'm having the same problem on the latest version of mp3tag and I don't have the update yet. It has nothing to do with I. It started happening when k got the latest version of mp3tag.
#4
And what are your findings to the checks I suggested?
PS: I don't understand what "I" and "k" should mean, though.
#5
I have it working for now, I just uninstalled it, deleting all files in the appdata folder, then reinstalled the standard version without unchecking any options
thanks
#6
or maybe not, its something todo with the mp3tag folder in your user :\temp folder, already existing or being deleted when mp3tag is open, then the dialogs start to freeze again
