Or itunes writes the modification only to its database, but leaves the file as it its. (Because how should MP3tag know what is stored in a file other than the actual tag information? There would have to be a second genre tag or something to store the old and the new information)
Could you check the modification data of such a file?
Hello . I Just Found A Bug In MP3 Tag 2.72. That Is When You Try To ( Remove Tags ) From An iTunes Song That MP3 Tag Can NOT Remove All Tags! You Can Easily See What I'm Saying In This Details About An iTunes Song AFTER Removing Its Tags Via MP3 Tag 2.72.
General
Complete name : F:\C Downloads\Compressed\Julia Volkova ( Keep Close ).M4A
Format : MPEG-4
Format profile : Apple audio with iTunes info
Codec ID : M4A
File size : 7.23 MiB
Duration : 3mn 38s
Overall bit rate mode : Variable
Overall bit rate : 278 Kbps
Encoded date : UTC 2014-01-20 21:00:02
Tagged date : UTC 2015-10-15 15:23:27
ownr : Yevgeniy Polgul
AlbumTitleID : 853884346
PlayListID : 1048312005
GenreID : 14</b><!--colorc--></span><!--/colorc-->
Audio #1
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 3mn 38s
Bit rate mode : Variable
Bit rate : 275 Kbps
Nominal bit rate : 256 Kbps
Maximum bit rate : 337 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 7.16 MiB (99%)
Language : English
linf : </b><!--colorc--></span><!--/colorc-->
The Lines Are Bold & Red Must Be Removed From Details But MP3 Tag 2.72 Or Other Previous Versions Can NOT Remove Them . Please Fix This Bug In MP3 Tag 2.73.
I'm Waiting For Developer's Answer. Please Quote Me. Thanks.
