I have configured Mp3tag 2.47a to remove ID3V1 tags and write only ID3V2 tags (tried both 2.3 and 2.4). However, after tags are saved, ID3V1 tag is still present in the file - the column tag shows it and WinAmp also shows it. If I remove ID3V1 tag in WinAmp, Mp3tag correctly shows that only v2 tag in the file.
It doesn't work that way. You need to use "File > Remove tag" to remove tags from the file.
