... I added a mapping rule "VorbisComment ALBUMARTIST BAND"), and it works as far as BAND display is concerned, but silently breaks the display of %albumartist%, causing it to falsely show null. http://img9.imageshack.us/img9/1950/picvh.png
This seems like a bug.
Attempting to workaround this by adding a mapping "VorbisComment ALBUMARTIST ALBUMARTIST" fails - regardless of the order of the two mapping rules. http://img641.imageshack.us/img641/5581/picj.png
If I would think that, I'd still think that currently - just one shows blank.
But two columns does not mean two tag fields. I already have multiple columns for a single tag field e.g. Album and EAN (taken by regexp from album).
And actually in this case I do have two tag fields - BAND (TPE2) and ALBUMARTIST - and the current mapping behaviour prevents me from showing which is active.
Yes, the format-specific field name is then not visible anymore (which is by intention, since you want to have one field name for a specific field regardless of the format-specific field names).
Actually I don't. I want to have one field name for all formats where required and still have format-specific names where required.
Florian, I have to ay I think this mapping implementation is misconceived. It would be better to map in the reverse direction - EDIT: each UI field name from a single file field name (for each format). Just like the current column label maps onto a single editable UI field. This would allow what is currently needlessly disallowed, and correctly disallow what is currently accepted but non-operative - multiple file field names (for the same format) onto the same UI field name. And thereby not break existing functionailty of the previous version. I hope you'll consider this change.
Yes, on this way I understand intelligent functional field mapping.
One UI field for all different tag formats, simple 1:n mapping.
All power emanates from the user, not from the tag format.
