Hello,
The app doesn't pick the ReplayGain info from APE tags for MusePack files.
Those infos are displayed and used by foobar2000 for exemple.
Just ask if you need some testing files.
Hello,
Have you set
File>Options>Tags>Mpeg
to read APE tags?
Of course I did.
I also tried to write them as id3 tags too, but still not appearing on mp3tag.
Are those stored in the APEv2 tag at all? MusePack usually stores the ReplayGain data in the MusePack header.
This info is available via information fields in Mp3tag, e.g.
_replaygain_track_gain (note the underscore)
