[X] Mixed Case on Mac OS Sierra not working : "file already exists"
Please take a look at the screen shot
This happens when using Quick Actions, choosing _allfiles, Mixed Case.
Error message : cannot be renamed, file already exists.
Is it a bug or am I doing something wrong ?
thanks guys
v2.82 on Mac OS Sierra
Hi guys, any idea on this please ?
Maybe the file system is case insensitive.
https://developer.apple.com/library/content/documentation/FileManagement/Conceptual/APFS_Guide/FAQ/FAQ.html ://https://developer.apple.com/library...e/FAQ/FAQ.html ://https://developer.apple.com/library...e/FAQ/FAQ.html
MP3tag is still a Windows application.
So somewhere, there is an emulator running. And NTFS (Windows) is not case-sensitive.
To rename a file you cannot only change the case of a letter, you really have to rename it to a new filename (like add an underscore at the end), then apply the new case, then remove the underscore.
No MP3tag bug but due to your environment.
in Upper case
you find an example how to rename files in principle. Perhaps the function $caps() is better for you.
Upper case
