I'm using MP3Tag 2.27a and Foobar2000 0.8.3 with ID3v2 plugin (WinXP Pro SP2). Here is my problem - after adding Replaygain info using FB2K, MP3Tag refuses to see most of the tags.
Here is the screenshot, which illustrates the problem: http://www.nncron.ru/temp/scrnsht.png .
There are two files: initial one ("INITIAL - 16 - Untitled (End).mp3") and one with Replaygain info added ("16 - Untitled (End).mp3"). MP3Tag can not see the tags, which are still there (I opened FB2K FileInfo panel and press 'Reload info from file' to be sure, that tags are not 'cached' somewhere).
I'm pretty sure there is something wrong there. Here are both files. Initial: http://www.nncron.ru/temp/INITIAL%20-%2016...led%20(End).mp3 and the one with Replaygain info: http://www.nncron.ru/temp/16%20-%20Untitled%20(End).mp3 . The each files is ~150K.
FB2K settings: Input - Standard Inputs - MP3 Tag writing: Id3v2 and Id3v1.
MP3Tag settings: Tags - Mpeg - Read: ID3v1, ID3v2, APE
It is interesting, that if I change the last settings to 'Read: ID3v1', the tags will appear again...
Do you understand - what is wrong?
Thank you.
CU
VK
