Under Options->Playlist check Create Relative [or leave at this default]
Load music files
Create playlist from these files
Expected result: relative paths in playlist file
Actual result: full absolute paths [i.e. K:\Music\musicfile.FLAC]
Checked by:
a) Inserting an external HD, which was mounted as K:\ on computer, into a Seagate Theater+ where the same HD becomes C: Opening playlist file with text editor
You mean it should work if I save the playlists on the same drive the files are on? But why should MP3Tag care were I save them if I only want the program to use '..' instead of 'C:[path]'?
Yes I do - you will get replative file references in your playlist.
Because it doesn't know that you want that... except by guessing from the location you use. The app could be more flexible, but I think current functionailty covers 90% of requirements.
