When multiple folders are opened, mp3tag writes only a single export file to the latest folder opened. I expected that every folder had its own mp3tag.txt.
Version: 2.41 and 2.41b.
You must check [X] One file per directory
What is in the Export file name field?
This is checked.
mp3tag.txt
Change the name to %_folderpath%mp3tag.txt
The best way to do this, open the config file and edit $filename function:
$filename(%_folderpath%mp3tag.txt,utf-16)
OK, it works. Thanks!
