I use the mIRC chat client with a script that uses a command $mp3($file).bitrate to display in text the bitrate of the particular mp3.
If I play an mp3 without having touched it with mp3tag 2.33 It displays the bitrate correctly.
Once i take the mp3 into mp3tag and change the ID3 tags and then play the mp3 in mIRC again I get an incorrect bitrate displayed even though Winamp tells me the mp3 is infact still 192kbps
I have also downloaded the dev builds 2.33a and 2.33b without success.
I went back to 2.32 and changed the ID3 with it and the problem does not occur
Why do people post on the forum and contact me by email on the same issue - I don't get it...
Does Winamp or another program also show different bitrates after files being saved with Mp3tag?
If not, it's a bug with mIRC, otherwise please send me the original file and the modified one for analyzing. My guess is, that mIRC fails badly on Unicode tags - so you might want to enable Always write ISO-8859-1 tags instead of UTF-16 at Options > Tags > Mpeg.
