It seams to be imposssible to connect to freedb, amazon or music brain with a proxy.
I have filled the informations in the options for the network connection but it doesn't work.
Is it a bug, or any trick to do this ?
Mp3tag only supports Basic proxy authorization which might not be the authorization protocol your proxy is using.
Kind regards
Florian
thanks for your reply.
Maybe can i help you to implement this fonctionality ?
I can make a bit of code with the connection on my network and send it you back.
On wich language are you working with mp3tag ?
