[X] Problem with MP3 comments
I'm using version 2.46a.
A comment stored with a description will not be displayed in TagPanel or Filelist.
But it will appear in the display of ExtendedTags (with the description showed).
Regards
Thomas
Interesting research, but where is the bug?
DD.20100409.1018.CEST
Since the comment field is included in the tag panel, it would be nice to see the comment here.
Instead I have to go via Extended Tags to see if there is a comment.
Regards
Thomas
Yes, this sounds unusual.
How many COMMENT tag fields do you see in Extended Tags view?
Do you see any text from the COMMENT tag field in a list view column?
How is the value formula defined for the comment column in the columns dialog?
What Tag types are involved in this file (ID3..., APE, Lyrics... etc.)?
Is there any mapping active that could interfere with the standard usage of the COMMENT tag field (see Options/Tags/Mapping)?
Is there any user defined Tag Panel entry that could interfere with the standard usage of the COMMENT tag field (see Options/Tag-Panel)?
DD.20100409.1331.CEST
I have a similar structure written for lyrics.
The result displayed in the tagpanel is:
eng|TrackLyrics|This is the lyrics
If I enter the following text in the comment field:
eng|TrackNotes|This is a new comment
a new comment is written with
Description = eng
Text = eng|TrackNotes|This is a new comment
Hope this helps.
Regards
Thomas
That's intended. ID3v2 Comments with a description are treated as separate tag field and can be accessed with %comment description%
Fine, but I can't get it to work.
Please explain.
Regards
Thomas
So what have you tried already? What isn't working?
I have tried creating field and refer that field to a %comment description%.
I also tried not to refer it, but then it creates a TXXX field.
I just want to know, how I can display in the tagpanel a comment, that has this content:
TAG = COMM
Language = eng
Description = TrackNotes
Comment = xxxxxx....
Regards
Thomas
For the tag panel add
COMMENT TrackNotes
as field.
If you want to add in the columns use
%COMMENT TrackNotes%
Thank you very much.
