I have this problem. I use field "www" and saved the MP3 file. All other fields are OK but this field is correctly displayed only in your software. In my player and in another tag editor it displays only this: "˙ţ".
Is this a bug or do I make a mistake somewhere? Thanks!
I had a look at it and don't see a problem with Mp3tag.
Most likely the other application can't read WXXX frames with an empty description. Which player/tagger are you using?
OK I find out what is the problem. I am using AIMP2 as my MP3 player in my PC and I realized it can't read www tag in UTF-16 format. I saved it in UTF-8 and it works just OK.
Thanks for your great tag editor!
