[EDITED:] ... returns YYYY rather than YY as documented.
[X] $regexp(X,.*$,YY)
The regular expression from the topic return YYYY because .* matches nothing and the X.
This is no bug and works as intended.
(Agreed - my typo, sorry. Original report now corrected.)
Indeed, as proved by $regexp(X,(.*)$,(\1)) -> (X)()
I have used regexp in dozens of other tools and languages, and never seen a single wild card expression generate TWO SEPERATE replacement expressions.
This is no bug
It is a failure to accord with the docs - * is supposed to be greedy i.e. match everything in one hit.
Are the docs in error, then?
"*" repeated any number of times including zero
That doesn't mean it isn't by default greedy. But
Non-greedy repeats
Non-greedy repeats are possible by appending a '?' after the repeat;
a non-greedy repeat is one which will match the shortest possible string.
surely does.
What's your understanding Florian? Is * (without ?) supposed to be greedy, or, not?
Sure, that's why there is an extra specifier to turn of greedyness.
I take that to mean "Sure, it is supposed to be greedy".
Well, Florian, then it is not working properly.
When .* is greedy, $regexp(X,.$,YY) gives YY because greedy . matches the entire input string, and that is replaced by a single occurence of the replacement string YY. This is indeed what I get on the other regexp implemetations I just tested.
But on Mp3tag, $regexp(X,.*$,YY) gives YYYY.
Actually that doesn't work either, but let's deal with one issue at a time.
PS Here's a quote from http://en.wikipedia.org/wiki/Regular_expressions#Syntax which whilst not necessarily being a spec Mp3tag aims to comply with, does define what's generally meant by 'greedy':
. The standard quantifiers in regular expressions are greedy, meaning
. they match as much as they can, only giving back as necessary to
. match the remainder of the regex.
