Hi
I'm not sure if that's a bug or not, but here is the case:
I copied an action from here, to remove 'double spaces' to 'one space only'
The action is the following:
Field: _ALL
Regular expression: \s{2,}
Replace matches with: " "(without quotes)
[ ] case sensitive
So, when I got a directory with 2 spaces, it does not replace them with 1 space only
then I duplicated the action above, but changing _ALL to _DIRECTORY, then it worked
so my question is, _ALL should not include _DIRECTORY too? Then _ALL should apply the action as well...
If this is not a bug, just ignore it
