dont know if this is MP3tag issue or winamp issue(never happened with winamp before i loaded mp3tag) If you right click on a track and sellect play an error appears "Entry Point Cannot Be Found In Winamp) when you cancel the error, the track plays as normal, but this happens on every track you select without fail???????
I don't see how this can be related to Mp3tag.
