please help me
Yes. And?
If you read the dialogue carefully, then it states
"... a detailed error description ...".
Does this have anything to do with the already as "no bug" classified thread to which you attached your post?
I've split the post to a separate topic.
hungvn, can you please give a detailed error description? You can also attach the log as stated in the message. It helps to track down the issue
Kind regards
Florian
