I'm getting this error, when I try to open the program, after that the program close.
Microsoft Visual C++ Runtime Library
Runtime error!
C:\Arquivos de programas\Mp3tag\Mp3tag.exe
R6002
- floating point support not loaded
Runtime error!
R6002
Can you please try the following:
Humm, I re-installed the program, and it was ok... after re-naming 2 Albuns now I'm getting the same error after I grab a song to throw on the program.
And yes, I did what you tell me. =/
OK, is it possible that the error occurred at exactly the same directory/file as the last time? If you're unsure, just try the above steps again.
Kind regards,
Florian
I tried songs from other folders and still getting the error when I drop then on the program.
Can you please send one example file that produces the error?
All songs that I tried to drop into the program give me this error, it isn't with only one song, and it's not a folder problem tho, because I tried to send file from my desktop and many others folders...
I can only use the program if I uninstall and reinstall the program, after rebooting the PC the program is dead again.
http://img35.imageshack.us/img35/304/errormp3tag.jpg
Do you have any other computer problems then this "Runtime Error" ?
A quick search with Google came up with this problem related to Virus/Malware infection
I only have this problem on my computer, sorry for the looong time to answer, I just remember of this crap when I need to use the MP3 tag = (
Does anyone know how to remove? I try to google some stuff about it, but not a 'REAL' answer...
Try to scan your system on viruses with freeware antivirus utilites, like
Dr.Web CureIt!
or
Kaspersky Virus Removal Tool
here or here
