Hi
I may be dumb, but when i do a Sentence case conversion on the title field, the first word is also in lowercase.
Artist, genre, and Album fields do not seem to be affected.
Can anyone confirm ?
TIA
Hi
TIA
No, I can't.
But: can you check your action to do the "Sentence" conversion?
On which tags do you perform the case conversion?
Which option have you set (normal, lower, upper)?
Which indicators for "end of word" have you entered?
What happens if you sort the files by title? Does the sorting order look weird? (This may be an indicator that an unwanted character like a blank has crept in).
Self reply: there was a space in front of all titles.
My bad.
