1 Load track 1 containing Carlos Gardel and 2 containing el
2 See Help "Filtering files and tags (Searching)" says:
3In Filter, enter el
Ecpected: only track 2 shown
Observed: both tracks shown.
All words from search string means that strings containing spaces are separated into words. These are then compared against the tag which is why I consider the 2nd option (both files are shown) as the expected behaviour.
If you think the help text can be improved here, I'm looking forward to your suggestions.
I dropped "tags or filepath" because I think the topic intrsuction covers that amply.
