After pushing
or
button and selecting "subdirectories" checkbox in the window the subdirectories no really scanned.
In the options I have "Subdirectories" disabled.
After pushing
or
Works flawlessly here.
That checkbox tells Mp3tag to also check the subdirectories of the selected folder for supported file types (MP3, AAC, WavPack, etc.).
Scenario: Parent folder containing songs and many folders with songs inside.
Action A: Click the "Change directory" button and select the parent folder. Don't select subdirectories.
Result A: Only songs in parent folder are added. Expected behaviour.
Action B: Click the "Change directory" button and select the parent folder. Select subdirectories.
Result B: All songs are added. Expected behaviour.
Action C: Repeat Action A. Then click the "Add directory" button and select the parent folder. Select subdirectories.
Result C: Songs in subdirectories are not added.
Is this what he is talking about? I can reproduce it and it doesn't seem to be the expected behaviour.
If you choose the same directory, Mp3tag won't start scanning it again.
Best regards,
Florian
