Hi Thanks for the mega program.
I recently updates to version 2.36. When I modified some tags I now get a little square at the end of most tags.
It only happened since 2.36.
I have rolled back to 2.32 again and the problem is fixed..
The problem does not appear in Winamp. It shows only in Itunes as far as I can see.
If I overwrite the last word with another random word and then re-enter the overwritten word the problem is resolved.
Hope you can help.
I have attached a screen print.
