Hotkey for Extended Tags window (ALT+T) doesnt work.
You have to select at least one file.
Can you please try to remove the registry key
HKEY_CURRENT_USER\Software\Moebius\Mp3tag\Settings\TagWndPosMaybe this solves your problem.
Tried.. still doesn't work.. shows the same thing
I'm running out of ideas...
Does anyone else have that problem?
Do you have any tools that might interact with the keyboard, such as programs for changing from Russian to English, tools that launch applications on key press..? Do you have any shortcuts on your desktop, quick launch bar, etc. that respond to ALT+T?
You're right! That was the program CLCL that was making that thingy pop up! I turned it off and now that tags window in mp3tag works! Thank yoU!
