[X] title field in wrong case
#1
first i would like to say thanks for this great app! i will donate again soon! anyway, i have noticed in this update that when i enter data in the title field the tag is changed from "Title" to "title". i dunno if its a bug but its kinda annoying. i cant seem to find anything in the settings that can remedy this. also, is there a way to a select list of tags in a one click fashion? thnx in advance.
Field names vary depending how Flac tag is saved
#2
What audio format?
Where do you see title instead of Title?
#3
thnx for the reply. it happens in both flac and mp3, but i think that it has something to do with dBpoweramp. i dunno but only the title tag seems to be affected.
here are some images.
unedited:
edited using mp3tag:
i edited all fields yet only the "Title" was was modified into lower case.
closed #4
