HI!
First let me thank you for Mp3tag. Perhaps, one of the best software ever written...
Windows 7 SP1 Home Premium
Mp3tag v2.58
I would like to report the following behavior, which might me classifies as a "bug":
For an MP3, when its title has " / ", that is, / with one space before and after, and Converting Tag - Filename, then the generated Filename, is the same, with the / been removed. So the Filename has 2 spaces in between. Example:
Title: Word1 / Word2
Generated Filename: Word1 Word2 (2 spaces)
But, for an MP3, with title containing "/", but with no spaces before and after, the generated Filename, is the same with the / been removed again. Example:
Title: Word1/Word2
Generated Filename: Word1Word2
So, its just not so nice. Perhaps, it would be better if it just replaced "/" with a space in this second situation?
Like: Word1 Word2
What do you say? And if there is a workaround for this issue, could you kindly tell me?
CHEERS!
