I searched for "null" in the forum and did not find a post relating to this problem:
If you choose a folder that has mutiple sub-folders and then make a global change (ctrl-a then alt-5) to add \\ to tags, when you subsequently select save (ctrl-s to convert the \\ to a null) only the first folder in your selection acquires the null. Following folders are left as \\.
I have only found this problem on the Genre tag since this is the only tag I am interested in having multiple entries separated by nulls.
root
+higher Folder (selected in mp3tag)
+-folder1 (genre tags get \\\\ changed to nulls)
+-folder2 (genre tags get saved with \\\\)
+-folder3 (genre tags get saved with \\\\)
+-foldern (genre tags get saved with \\\\)
If I then enter each and every sub folder (ctrl-d) select (ctrl-a) and choose save (ctrl-s). The null is entered correctly.
I would like to be able to do this in one step instead of having to go into each folder and save the tags.
I am using Foobar as my music player and it shows the multiple genre tags as entered, separated by nulls in mp3tag.
Regards.
I forgot to add the [AF] in the topic. this forum will not let me alter the topic...
