I load a single song in mp3tag v2.42e (same behavior in v2.42). The display panel shows a song length of 07:09 (this is correct!). I change the genre tag and save tags (any tag field change will do). The display panel value for length is still correct. I now change the tag I go back and "change directory" to the same location to reload the file in mp3tag. The length for the song now changes to 37:52.
This is now the permanent entry for the song length.
I've now witnessed this behavior on multiple CDs (I noticed it when I exported CD information and
discovered a number of CDs that had total lengths beyond ~80 minutes.
I can send an example mp3 file if that would help. see screen dump files "startup" and "after"
Louis
startup.pdf (16 KB)
after.pdf (16.1 KB)
