When I want to remove tag fields from MP3s using the extended tags dialog, it fails, when it is either ID3v1 or ID3v2 tags being read (no APEv2 tags present in files).
Works as expected with APEv2.
PS:"fails" means they are left untouched, the old metadata is still there.
EDIT: Oh I have to enable "Write ID3v1 and ID3v2" in order for it to work?!? But I keep them disabled because I usually convert to APEv2, and I don't want to mistakenly write ID3 tags since ID3v2 take really long... when I keep ID3v1/2 writing enable and I edit the tag fields of an MP3 that was stripped off by these tags before, they get written back.
So after each edit an MP3+APEv2 file I have to press CTRL-R (my Remove settings: [x] ID3v1, [x] ID3v2, [ ]APEv2) afterwards for the damn ID3s to be removed again!
Florian, please can't you finally improve this? I have posted it so many times that the current Tag Options (Read/Write/Remove) means nothing but trouble. I have to go to "Options->Tag->Mpeg" much too often, it's so complicated and confusing, depending on what I want to do with the MP3s I have to change the settings there each time. ![]()
