As I have no WMA specification at hand, I'm a little unsure if "COMMENT" should really map to "Description" (what kind of field is that?) or to "WM/Comments" because I've seen both .
(Picard uses "WM/Comments", for instance.)
Florian, any hard facts on this?
Florian
January 20, 2009, 10:56am
2
See MSDN: Attributes for Music Files where Description is listed and WM/Comments is not.
Funny, that you've posted this as bug report.
Thanks for the link.
Well, since I had no specs, I thought this might be the best place (in case it was a bug). And I knew you would know the answer offhand
Then again, I just found it it in the official »attributes that correspond to ID3 tags« list . I guess that’s also the list MusicBrainz use, have to ask Lukas.
But I agree now that »Description« seems to be the »more general one« and thus should be used in Mp3tag.
Florian
Closed
December 28, 2018, 2:24pm
4
