Hi Florian,
I'm still very happy with mp3tag, but I did found a small problem.
I was under the impression that PCDJ DEX was the cause but after investigation with Gwen Roelants, the developer of DEX / djdecks we did find that mp3tag is the cause.
My problem is:
I have a song, a time ago I did fill the WPUB tag with "Kerstmis".
Maybe in a sort of batch within mp3tag.
Recently I saw this song come up within DEX because of a smartlist created WPUB contains "Kerstmis".
But as I didn't like that song I would like to delete the WPUB entry.
Opened in mp3tag, the song didn't display anything within the WPUB field, so I was confused.
After a lot of tests, I found out that if I edit whatever tag entry in the song the WPUB field was removed, so didn't show up again with the smartlist in DEX.
That gave me the impression that DEX did find somewhere else in the song the text "Kerstmis".
But that's not true.
So I can watch the song within mp3tag, without seeing the WPUB entry, if I don't touch it it isn't changed. (Checked with wordpad) But if I do change something and the tag is saved, the WPUB is gone afterward.
What triggers me is that when I open the song in wordpad I see empty spaces after WPUB and before Kerstmis, could that be the problem and how can they be added?
This is the only tag entry I have problems with.
I did try it with v2.44 but I also installed the latest one today 2.45a and it has the same behaviour.
You can see also the discussion on PCDJ DEX troubleshooting forum:
http://67.18.16.226/~admin/showthread.php?...5887#post125887
It's at the end of this thread.
Can I send you this song to investigate?
Best,
Dj Antoon
