I've just analyzed the one file of the screen shot where mp3tag 2.42 shows 32 kBit/s and 48.000 Hz - but other software shows 320 kBit/s and 44.100 Hz (and it sounds like that).
Here is the analyze of the 32-Bit-Header:
00000000h: EE 56 A0 00 B9 90 69 7D CA 54 00 26 DE 17 5A 19; îV .¹�i}ÊT.&Þ.Z.
and the header definition (the number of bits in paranthesis)
A Syncword (12)
B MPEG Version (1)
C MPEG Layer (2)
D Protection Bit (1)
E Bitrate (4)
F Sampling Frequency (2)
G Padding (1)
H Private (1)
I Channel-Mode (2)
J Mode-Extension (2)
K Copyright (1)
L Original (1)
M Emphasis (2)
which are the bits:
A 111011100101
B 0
C 11
D 0
E 1010
F 00
G 0
H 0
I 00
J 00
K 0
L 0
M 00
E (Bitrate) = 1010 which is in the table under MPEG 2 / Layer III => 160 kBit/s, but mp3tag.de shows 32kBit/s.
F (Sampling Freq). = 00 = 22.050 Hz ... and not 48.000 Hz
Hmm .. all sounds very mysterious with this file .. RealPlayer shows 320 kBit/s, Tag & Rename shows 320 kBit/s & 44.100 Hz (Lame 3.82), Directory Opus plugin shows the same values as mp3tag - but it's definitely not 32kBit/s
Please let me know if you need the MP3 file - THX.
You didn't pick up the right sequence (frame header) since syncwords have the first 12 bits set, so it should be something like FF F? and definitely not EE ??.
