Actions and batch-operations
How to change upper/lower case of tag fields or filenames?
Create a new action in an existing action group and choose Case conversion as action type.
  • Field determines which parts of the tags/filename should be changed.
  • Case conversion determines how the upper/lower case of the field will be changed.
If you want for example mark chars after a left parenthesis or a hyphen as the begin of a word, enter the respective char under Words begin from/after any of.
