Actions and batch-operations
Mp3tag provides a variety of actions, which can be applied to filenames and tags. The actions are grouped together into named sets (action groups), which can be applied independently via Alt + 6. If you do not want to create a reusable action group for applying one single action, the Actions (Quick) toolbar button or keyboard shortcut Shift + Alt + 6 can be used.
How to create a new action?
How to ...
Batch file tag processing?
Tracknumbers (again)
Batch file
Adjoining extra text to a field
How to find trailing spaces?
How to batch Im-/Export of Cover Art?
Question about cover art
Copy values between fields with regexp
Creating an action plan to add role/name (;)
Copy Artist to Title and include brackets
Changing Directory Name
Are batch actions possible ?
Adding Text To Title (Sorted)
Four questions from an enthousiastic newbie
removing certain text from title and name
Action to replace "[ ]" by "( )"
Album art with FLAC files
I want to add information at the beginning or end of title field
[X] Spaces at the beginning and end of tag fields
REPLACE values after utmost left character
Move THE to end of artist tag
Insert Space Between Words
Add To "Title" Field
Remove cover tags recursively
Tag Tracks With Multiple Artists
Spiliting One field to two fields
[Formating] How can i format, rename and export
Reduce the number of genre tags to just ONE
How to remove part of Title for a number of songs
How To Edit Composer List
Cutting & pasting fields
Replace multiple strings
howto change tracks from 01/16 to 01 format
Artist/ Album Artist
Find and Replace list of Album tags
Insert Character at the end of a Field
How can I remove 'underscores' from filenames & tags?
Reverse artist
Create an action to copy from one field to another
itunes and filename
Replace (---) with -
Removing Brackets
Various Artists Name Change
Mass Edits
Simple way to change all entries for single field
Remove trailing spaces
Number and Hiven
Switch title with artist
How to create a Tag Template
Re-Tagging Scripts
Change BPM
Regular Expressions
regular expressions
CAPS script
Removing WWW addresses from MP3 filenames
Titel und Interpret in 1 Arbeitsgang tauschen?
How to remove space in ID3 title
Adding the same text to artist name without removing any tag info
[WS] iTunes
Tag based on folder information
How to change
Script to import music review files into comments field
BATCH method to import album art from file to tag?
Copying "Artist" to "Album Artist" in iTunes
replace é with e
How to insert dash between words?
Tag - Tag Convert
composer tags from artist names
Amend Album Name with Artist name
Find and Replace in tag
Convert
How to change UNSYNCEDLYRICS language identifier?
Action to remove leading zero and total tracks
Combine artist and title
Find and replace in names
Regex to append to Genre
Replace TITLE with current TITLE and ARTIST
file name & title name fields
Adding "totaltracks" tag en mass?
Can I arrange titles the way they are recorded?
How can I replace characters in the file name
How to delete numbers in the file name?
Copy and Paste
Track Number auto filled in titel
Extract text from title or filename
Moving artist from parentheses in song title to artist field
Need help with IF function script
How do I copy "Album Artist" info to "Artist" field?
Possible to batch Copy "Title" to "Part"?
Action Groups
Automatically embed a image to all songs in a folder?
Multi sequential assigment images / cover / jpgs join to mp3 ?
Moving Data from One Tag to Another
move a part of tag to another tag
Remove portion of title in brackets
Search and replace/delete function missing
replace the last space of the title
Insert Comment in front of Album Title
Setting to Automatically Populate 'Album Artist' w/ 'Artist' value?
Empty space in Title field
Create New Action
How to create Action for Convert Filename - Tag
FLAC - Composer issue with semicolon separator
Convert Tag -> Tag
Action to remove hyphen and add brackets to start and end of artist name in filename and track title
Cover Art and Filename
How can I use ID3V2 to remove embedded artwork and add a link to artwork on my hard drive?
Help with conditional and regex
Column Dropdown
Trying to remove leading track numbers
How to remove parentheses and move contents
Live Anhängen
Is it possible to make an automatic script?
How To Insert A Phrase "X" Spaces From The End Of The Album Name
Updating one field with contents of another?
Conditional Update on Album Name
Copy Album Artist field to Artist field IF empty
Remove THE from start of Artist field
Is there a way to convert capital letters to lowercase?
How to Add word to title or filename
How can I do this.. Help me plz.
Auto-tag cover art for collection
Simple tagging question
I need to combine title with year in the title field.
How to copy MP3 metadata/tags created in iTunes?
Fill Title Tag with data from the filename
Wie richtig Taggen? ARTIST + ALBUM ARTIST?
Recommendations for Bulk Library
Remove square brackets
How to append tags?
replace %artist% (tag) and %title% (tag)
filename to tag help
Punctuation Problems
How to add a name in front of the title tag
Copy Filename to comment (before renaming file) - how?
Modification of tags for mp4 and case conversion
Copy from one tag field to another.
Batch-mode for integrating cover.jpg as mp3-tag
Replace Repeated Tags
How to add a Word after each filename and title of Mp3
underscore
Audiobook Tag Issue
replace characters
How do I ...
User tagging action presets?
Importing Tag Data without Deleting Current Tags
BPM help pls!
Help - change title tags
Title case
List of ready made actions to add
How to swap tag fields
Newbie Struggling
Filename - Tag Comment Field
Artist and Album Artist
Can I change part of a title?
Switch fields action
renaming/string issue in one particular case
Album issues...
Truncation of comment field to 256 characters
Feature Suggestion: Folder rename
TAG Titelleiste anpassen
Case Conversion of Title
Discnumbe, Album Artist, Composer fields
delete all but cover images
Add same line to lyrics in multiple files
Changing file paths above the parent directory?
Organisieren von Compilations
Getting Traktor to see Foobar Ratings
Need to know the reg exp for following
How to rename folder based on Album tag
Custom text in Filename to Tag? or Combining Fields?
Insert Track number into Title
artist - title want to remove artist
MP3Tag und Picard
remove all but one tag field
Filename to Title
Append text to track title
No Spaces In Filename
Customize for Mobile device
How can I modify TRACK please?
Text File - Tag - Tagging Comment with ultiline
Track numbers
Titelnamen in Albumnamen übernehmen
Copy Titlename to empty Albumfield
'And' for '&' or vice versa
Länge des Tracks automatisch in ID3V2 Tag
removing/changing fields names in extended tag window
Want to extend strings
Make Album artist = Artist field
Removing Underscore
Remove string from filename
Various Artists tag reformat
Custom Tags, etc. (bugs and additional options)
Remove Artist from Title
regex - where and how?
Release Date field in itunes
Blank spaces after Title
Automatically Save Cover Art
Strip all tags except the main ones...
extract cover art from multiple directories
How to get title & track number in 'title' field?
remove
Tag - Filename [Track Number Code]
Strip Specific last character of a Tag File
Find & Replace text in tags?
Automate the albumart process?
Remove/trim leading track numbers
Adding to existing Field
problem with codpage
Adding leading zeros to an extended field
Leerzeichen vor großen Buchstb. einfügen
lower upper case in parentheses
Inserting Spaces
Import covers and other setting from WMP11?
Artist / title in the same field
Switch Title and Artist
Append Comment to Title
Capitalize first letters in a tag
How to change a blank for underlining?
Tag to tag conversion? Missing Action Groups?
Title and Artist
Settings for changing .flac and .ogg tags
Not so newbie questions...
Various Artists Bulk Convert
Delete trak number from title
Quick Questions - Help me out, I'm new! :D
Sprachumschaltung
Delete track number
Help req'd merging fields...
Renaming directories
Case Sensitive with prepositions
Suggestions for enhancements
Suggestion: new Action: Convert Russian characters to Russian Unicode
Remove Track Numerals
Tag to Tag?
Need to remove first 2 characters from mp3's
First letter of artist?
Rename from tag (fractional track numbers)
Trim Filename?!
How to replace the Title tag with filename w/o extension?
Automatic/scripted import of album cover
Allgemein
Removing Artist out of the Title
Tags from lowercase to uppercase character
Copy/move ARTIST to ALBUMARTIST
Rename "Tag With Uppercase" to "Tag with uppercase"
How to copy artist AND titel to titel
Removing numbers from FILENAME
Changing part of the title .
Replace /, \ with &
Appearance of multiple album art
Changing File extensions
Cut filename MP3 for mastering?
Remove middle part in brackets from title
Quotation Marks
Suggestion: Remove x number of characters from a field
Where's "Tag - Tag" conversion?
Rename filename - tag
Track und Titel vertausch - wie rückgängig machen?
How to Change TagsLikeThis to "Tags Like This
Insert a constant into a field
Insert a word into all titles
New suggestion
Action : copy filename to %title% or to %work%
Auto Adding a Space After a Period
Add some text to Title for multiple files
How to bulk move tag data to another tag?
Trailing white space in Artist tag
Convert tags from aaa to Aaa
Replacing a word if possible
Capitalize between brackets
Regex to fix year\\year and year\\year-month-day
Problems with Cover Art count
Mixed Case - special cases
Moving from Field to Field?
FolderNames -> Tag?
Add Artist to album tag
Adding something to an existing tag?
import cover art from file
Is There a Way to Build User Input into an Action?
Swap tag fields
Replacing ...
Swap Artist / Album Title around
Converting track numbers
changing only part of a tag
Delete Filename Based On Current Folder
Easy Editing of titles would be helpful
formatting mp3 tags
Rename files and tags with specific name
building my own tags
deleting directorys after renaming
Need Help With "Case Conversion"; Scripts
Modify Tag
How To Capitalise Post-Brackets Characters
Modify Tag
How to use the the replace function within tags?
Adding artist name to album name
Concerns....
Concerns....
Concerns....
How to import lyrics from likenamed textfiles in batch?
Need help to do a batch rename
How to delete separate part
Special Characters added to title
" (feat.) " problem
Do I need to tag in order for what I want to do?
How to add year to Folder "Album title"
divide different values from title
convert charset encoding
Inserting album pictures into tags
Capitalizing every first letter even after ( [ characters
Remove number from artist field
Swap Title & Artist values?
Replacing straight quotes with curly quotes "text">“text”
New here: How do I...
Several lines in "comment"
script to input character(s) to any field of choice?
after compter froze, all my albums label fildname changed to organization
Want to Tag my mp3 song names without the song number
How To Get A Capital Letter
paragraph align Left but keep spacing
how to copy album artist to composer
Change tag from tag
Help needed: Edit multiple tracks with wrong field info
I want to separate two words with Space after comma
Add Renaming Features
Newbie needing scripting help please :)
Filling the COMMENT field with data using REPLACE
Mixed case for French language?
Is it possible to append Extra info to the title of each song in an album at once?
need more efficient approach
Delete All Text After Word
How to batch change word 'FLAC' to 'ALAC' in Album field ??
Sequential MP3 Title numbering......re-visited
How do you add action groups to Mp3tag?
Rename If Extension
How to Removing Title ending with zeros? ?
Search for song names in freedb etc.?
How do I strip metadata?
Separate all album artist in one tag field
Batch to Remove 1st then Add
How to merge Artist + Title into "Title" field?
Merging Different Fields?
How to remove a word and replace it with blank spaces
Merge tags
Names With Apostrophes
Assigning one field's value to another
Tags austauschen
How to remove track number from filename
insert albumartist from artist
First, create a new action group via Actions > Actions Actions or Alt + 6.
Then, click on the button New New and give your action group an expressive name, e.g., "All tag fields Upper Case". This action group can be applied to the selected files after you have added one or more actions to it.
Now, you can create a new action in your action group via the button New New and choose the desired action type from the list.
At the moment the following action types are available
You can combine different actions (e.g., Case conversion and Replace) in one action group and activate or deactivate them via the checkmarks in the Actions > Actions Actions dialog.
Mass Tag/Filename Conversion
Editing Titles to be 'Artist - Title'
Export Action to txt
duplicate tags
Can i copy a field to another?
How do I do actions/scripts
Do all this in one click?
Batch Removing Part Of The Comment Tag & Adding It To The Album Tag
Working with multiple Genres and Instruments
Batch Edit Album Art from Progressive to Baseline Support?
Create a Master Tag file
Removing (Automating) Slashes
Want to Replace - But Am LOST
Copy TAG
How do you add a custom name to "Comment" section as the defalut?
Help removing question marks and other characters from title
Adding Coverarts to same-name-mp3file
How to execute a script in mp3tag
Capitalize First Letter after (
How to set default desired values in tag field
Looking for New User Help
Discogs Questions
keep seperator in two segment filename to tag
Batch autotag different fields?
Copy a tag field in other tag field, not working!
Extracting artwork to album folder - is that possible?
How to export cover art to directory structure
Year Category Needs Correcting
Adjust Cover ; how where.?
Custom action profiles .mta
Tag-Felder kopieren?
How to I automatically put the second artist into the title
Tag remove problems
Apostrophe vs. Accent aigu
Second Art Cover for Bonus Album
Extract and create cover files for a large number of folders
Titles disappearing
Batch change the folder name based on the tags of the files inside it
My .mp3 files no longer have embedded images
Freezing when trying to get album art
Rename based on certain tag fields incl. regexp
Tag panel option to insert value or fomatted string
Mass Edit of Charactor
Create A New Action to swap first name last name to last name, first name
How to retag using batch file
How to change upper/lower case of tag fields or filenames?
Create a new action in an existing action group and choose Case conversion as action type.
  • Field determines which parts of the tags/filename should be changed.
  • Case conversion determines how the upper/lower case of the field will be changed.
If you want for example mark chars after a left parenthesis or a hyphen as the begin of a word, enter the respective char under Words begin from/after any of.
How to replace the string "xyz" in tag-fields or filenames?
Create a new action in an existing action group and choose Replace as action type.
  • Field specifies the parts of the tags/filename the replace rule should be applied to.
  • Original is the string that is going to be changed in Field.
  • Replace with is the string that replaces the string in Original. If you leave it empty, the string will be deleted.
How to append the string " xyz" to the content of a tag field?
Create a new action in an existing action group and choose Format value as action type.
  • Field specifies the tag field the formatting rule should be applied to.
  • Format string must have the field placeholder for the field selected above and the string which should be appended.
Example:
If you want to append the string " xyz" to the current value of the comment field:
Action type: Format value
Field: COMMENT
Format string: %comment% xyz
You can use this also to add "xyz " in front of the tag value, combine fields or to copy one value to another field.
String-manipulations
Append Album Name at the beginning of the Title
Appending [xyz] does not work (Actions)
convert from tags to tags
Adding band name to album title?
Remove Album from Title
How to add the same text to the tag for all files
String Adding and Numbering Question
Exchange/Move/Copy values of tags
Rename file only if extension matches (.Mp3, .Flac, etc)
"Actions" variable questions
How to Add/Remove one word from multiple songs names
Where to enter scripting function?
Add year to end of album name
Adding Genres (not replacing)
Convert automatically "comments" to "album"?
Insert Text in Credit Field
Disc number Sequential Action
ORIGYEAR tag confusion!
Add text to comment
Bulk Add/Remove extra information to Tag Fields?
Format Comment Field with Bitrate?
Add [artistname] to [trackname] / Merge fields
New Feature Request
Combine tags on filename
Compilations and modified titles to include artist in brackets
Adding text to beginning of existing comment
Add to a tag, but keep already existing
Append tag to variety of existing tags/files?
Need help with Artist tag w/multiple files
Complex manage featured artists, moving & copying between fields
Add DR (Dynamic Range) value to album title
Help me stitch the year to the album name on the album name field
Add a string, not replace it
How to move a tag to another field
Tagfeld Kommentar - Informationen ergänzen
add genre to existing multi genre tags
iPod Touch lyrics tag as track info
Add "Cd #" to "%ALBUM%" for albums with multiple CDs
how to add names in end of file name
Wort anhängen
No Change in File Tags
Searhing artist in compilation albums
Append to existing title for batch of selected files?
Disc number from folder name
How to use <Reserved> correctly?
Add a txt to title
Revise Multiple Album Titles?
Appending to existing genres
How to add text to multiple existing tag fields at once
Add S(Series)E(Episode) to Track or Title
Simple request -- append one field to another
Applying information from one file to another based on file sequence
How do I add a "word" after the name of artists?
Pulling location from directory into an action
Appending the same string of text to a batch of track titles
Adding words to title in MP3 on multiple files at once
Year tag manipulation
How to import a custom action group from a file
In ganze Spalte ein Wort anhängen
Adding info to a tag
Adds a word to the end of each song
How to remove text strings?
In order to remove text strings, create a new action in an existing action group and choose Replace as action type.
  • Field: Here you can enter which field(s) you want to change.
    You can choose
    • _ALL, which affects tags AND filenames,
    • _TAG which affects all tag fields,
    • _FILENAME which only affects the filename,
    • or simply one of the other supported tag fields.
  • Original: Here you enter the string that you want to delete.
  • Replace with: Just leave this empty, because you're going to delete the string in Original.
Example:
Assume that you want to remove Obsolete from the filename ThisShouldRemainObsolete so that ThisShouldRemain is the result. To achieve that, just enter Obsolete at Original.
How to add additional spaces around dash?
In order to get better readability for a filename like "Artist - Title", you can add spaces so that it reads "Artist  -  Title"
Create a new action in an existing action group, choose Replace as action type and enter (without the quotes):
  • Field: _FILENAME
  • Original: " - "
  • Replace with: "  -  "
You can activate the action group via Convert, Actions Actions and apply it to the selected files.
Unintended duplication of spaces can occur, if you're executing this action several times. "x - x" becomes "x  -  x", and "x  -  x" becomes "x   -   x" etc. You can prevent this by adding a second action that makes "   " (3 spaces) to "  " (2 spaces).
It is even more simple if your files are already properly tagged: you can use the converter Tag - Filename Tag - Filename with the format string "%artist%  -  %title%" and get the same result.
How to remove a certain number of leading chars?
In order to remove some leading characters from the filename or a tag field, create a new action in an existing action group and choose Replace with regular expression as action type.
  • Field: choose where you want to remove the chars.
  • Regular expression: enter ^.{3} if you want to remove 3 chars.
  • Replace matches with stays empty.
You can enter the number of chars to be removed between the two curly brackets.
To remove the last 3 characters use .{3}$ (but do not use this on _FILENAME as it would remove the file extension).
How to remove specific leading characters?
Some titles start with "The", others with "Der" or "Die". Mass-deleting the first 3 characters doesn't have the desired result, because all other tags/filenames will be shortened too.
To remove specific leading chars, create a new action in an existing action group and choose Replace with regular expression as action type.
  • Regular expression*: enter ^The\s+
If you execute this action on your selected files, all The's and following spaces will be deleted. Of course, it works the same way with any other word.
How to remove/trim leading and trailing spaces
Video tutorial for these actions
Leading spaces:
Action type: Replace with regular expressions
Field: _TAG
Regular expression: ^\s+
Replace matches with:
^ matches the beginning of the string. Then \s+ searches for all whitespaces till a different char occurs.
The whitespaces found will be replaced by nothing and, thus, deleted.
Trailing spaces:
Field: _TAG
Regular expression: \s+$
This regular expression matches one and more (marked by +) spaces (marked by the \s specifier) at the end (marked by $) of a string.
Trailing spaces from filenames:
An action that doesn't remove the file extension:
Field: _FILENAME
Formatstring: $trim(%_filename%)
Cut two or more consecutive spaces to one:
Field: _ALL
Regular expression: \s{2,}
Replace matches with: " " (without the quotes)
How to remove/trim leading track numbers?
Regular expression: ^\s*\d+\s*-\s*
This regular expression removes the track number from 01 - Anything.. so that only Anything... remains.
^ matches the beginning of the string. Then any numbers of whitespaces \s* followed by numbers from 0-9.
The \s*-\s* part removes the hyphen and any whitespace characters around it.
How to separate or split strings that are written in one word?
You have titles that have no spaces between words (written in one big word) and all words start with a capital letter, e.g., ThisIsTheTitle (also referred to as CamelCase). How can Mp3tag separate the individual words and insert a space before every capital letter?
Create a new action group, e.g., TagsLikeThese for the field you wish to edit (the example uses the TITLE field):
Field: TITLE
Regular expression: (\l)(\u)
Replace matches with: $1 $2
[x] case-sensitive comparison
or
Regular expression: (\w|,)(?=\u)
How to apply upper case after an O' (like O'Hugo)?
There are irish/scottish names like O'Donnel, O'Leary etc, that all should be upper case. But you cannot use upper case in general after an ' because other words would be spelled wrongly then (That'S, Ain'T etc.).
Regular expression: O'(.{1})
Replace matches with: O'$upper($1)
How to swap the contents of 2 tag fields?
Example how to swap TITLE and ARTIST:
Create a new action in an existing action group or make a new action group.
Action type: Guess values
Source format: %title%~%artist%
Guessing pattern: %artist%~%title%
Note: The ~ sign is just used to separate the two fields, you could take any other sign that does not appear in your fields, e.g. ¢ or an extended unicode character like ∞ or ∑.
How to copy one field value to another field?
Example how to copy the content of the ARTIST field to the ALBUMARTIST field:
Field: ALBUMARTIST
Format string: %artist%
Note: If you want to copy all possible values of a field (in case you have multiple artist fields), the internal scripting function $meta_sep can be used in the format string, e.g., $meta_sep(artist,\\\\)
Copy artist to album artist
Cloning fields
Replace every Album Artist with Album Name?
contributing artist tag ?
How to "Replace"
Autofill Fields
Batch Operation: Copy SOLOIST tag to ARTIST tag
Regular Expression Needed, Please
Copy album artist field to artist
How do I store values in variables
Copying Title to Album - Action
Remove characters after / before
Where is the PERFORMER tag?
Replace a field from other fields
List Artist based on name not prefix - The Cure under C not T
How to autotag ORIGYEAR into YEAR field? If not exist > oldest release date
Why does the cover art get mixed up when I play my songs in a music app?
Editing lyrics
Metadaten Tagfelder verarbeiten
Titel in Album Speichern Aktion?
Tag field mapping
Actions (Quick) - code/string for all info in field
Easy way to duplicate Artist as Album Artist?
Removing "the" from multi artists
Copy Sort Composer tags to Composer
Moving one tag field into a different tag field
Tag von einer Spalte in eine andere Spalte kopieren
Create an action to duplicate fields
Reformat Artist tag for use in Album Artist tag
dbPoweramp extended tags detection
Need help about how to move content from Album to Genre
Copying Fields and Adding them to Blank Fields
Copy one tag field to another
How can I create hundreds of single-file albums?
Album Artist shows in iTunes but blank in Mp3Tag
Automatically copy Artist and Album Artist
WMP Rating to ROONTRACKTAG
One-click distribution of a name to two tags
I want to auto-populate sort-names in meta tags as well
Problems displaying composer field properly v3.01
How to have tag panel item refer to other tag
Artist data suitable for Windows 11 Media Player
Mass editing MP3 metadata across many folders
MP4-Tags with superfluous null bytes at the end are not shown in MP3TAG
Script für Hitparade.ch erstellen
Help dealing with albumartistsort
How does one use the Quality field in the tags?
Compilation Jahr vs Song Jahr
MacOS Voice Memo m4a files - Recording Date
Could be added the copy fild in the action?
Feldinhalte in selbst erstelles Felder kopieren
Batch Convert Artist field to Album Artist and vice versa
MP3TAG erases tags while doing group tag editing
Artist vs. Contributing Artist vs. Album Artist
Copying data from extended tag (catalognumber) to custom tag (CATALOG)
Inhalt der Spalten copy?
Copy value from YEAR tag to DATE tag
Automatisation Formatage fichiers
Copy Field Value in another field
Copy sync lyrics tagged to the field SYLT help
Add new info on multiple albums and files
Show "Rating POPM" in column
A method to produce DISPLAY ARTIST
Copy TLEN to Length
Organizing Actions
Keyboard Shortcuts
While it's not directly possible to assign arbitrary keys to action groups, you can use the keyboard shortcut to trigger the action group menu Alt+A in combination with another character from the action group name. Simply decide on the character and prefix it with &. You can then use Alt+A and the character to trigger the action group.
An example action group &Uppercase can be triggered by Alt+A plus U.
Submenus in the Action Group menu
If you use the # in your action group name, Mp3tag uses anything before the # as name for a submenu and anything after as a menu item in that menu. By that, you can organize action groups that belong together.
An example action group Default values#Set COMMENT would create a submenu Default values and would list the action group Set COMMENT within this menu.
Pro tip: you can combine both tips, e.g., &Default values#Set &COMMENT to trigger the action group by pressing Alt+A plus D plus C.
