Hello,
i would like to add genre and styles from discogs to the genre field of my mp3 files in this format:
Mp3-Genre: DOGs-Genre/DOGs-Style1/DOGs-Style2
how can i implement this? From the looks of it, mp3tag doesn't fetch the style tag?
Hello,
If you have a look at the Websource Script source code for Discogs in a text editor like Notepad++
%appdata%\Mp3tag\data\sources\Discogs.inc
you will find this lines:
This indicates that Genre and Style should be fetched - if available at Discogs.
Do you know a real example, where the Genre and Style is available online, but not applied to your matching tracks?
With such a real example we could try to combine the contents to your desired format
You're right. silly me. Style is fetched as an extra tag.
I think I only need one action to bring this together in the genre tag.
https://www.discogs.com/de/release/3851951-901-Thugs-901-Thugs
Please show us a screenshot of one of your currently tagged tracks after pressing Alt + T (Menu View -> Extended Tags).
This way we can see what kind of tags we should combine.
