Hints for asking Support Requests
If you need support using Mp3tag, you can help the community members that are about to support you in finding a solution or workaround to your problem, by following these simple guidelines.
Be descriptive, also in what you’ve already tried
Please give a short explanation what’s not working as expected or what you’re trying to achieve. It’s best to know any details about the problem at hand and especially, what steps you’ve already tried to solve it by yourself. Helpful information also includes the Mp3tag and Windows version numbers and what files types you're working with. This way it's easier to know where to start helping.
Also, please use a descriptive topic title that gives a general idea about the contents of your support question. Do not fall back on non-specific.
Use the Mac category for asking questions related to Mp3tag for macOS.
If you're asked any follow-up questions, please assume the best intentions, be as helpful as possible and try to answer in earnest and with the best intentions.
Use screenshots to exemplify the issue
It’s often helpful to see what you’re doing. Because nobody here can look over your shoulders, a screenshot sometimes adds detail to your description and an experienced user can spot issues, that are not obvious for others. Especially for questions regarding tag contents, missing tag fields, and other tag-field related issues, a screenshot of the Extended Tags Dialog of the file in question via Alt + T is often helpful.
Please use screenshots to complement your description.
You can use Ctrl + V to paste a screenshot from the clipboard or use the upload button from the format palette.
Discourse Upload Image
Check problematic files for errors
If Mp3tag reports that the file cannot be opened for reading or writing, it’s often related to an invalid internal structure or an otherwise corrupted file.
You can spare yourself (and the people reading your question) a lot of time and back and forth by checking the files for errors using one of the recommended programs linked to from: How to check files for errors?
An early indication of such a problem is when Mp3tag doesn’t report any details about bitrate, length, … in the respective columns in the file list.
Starting with Mp3tag v3.12a, it also reports some of the issues found to the Tag column in the file list. Please make sure you check those.
Invalid File denoted in Tag column
In many cases the troublesome file may play correctly in some or all media players or may be editable in other metadata editors. However, this is not an indicator of whether the file structure is valid or not. In contrast to just playing a file, Mp3tag re-writes the metadata part of files and takes a cautionary approach when performing changes that might affect the audio part to prevent data loss or more damage.
Use formatting when necessary
If your topic involves a format string, please enclose the format string in backticks `, e.g., `my format string` so that spaces and other special characters like backslashes \ and stars * are preserved by the forum software.
You can also use Ctrl + E to mark the selected text as preformatted or use the corresponding symbol from the format palette.
Discourse Format as Code
Freezing when trying to get album art
Incorrect filenames lead to incorrect titles
Edit track number
How to fix mass of mp3 wrong times? after editing 50000 songs, times all wrong
Ver 3.14 bug: file "cannot be opened for writing"
Errors after adding ay new Tags
Import tags from TXT or CSV
Album Art not Showing up
Tag to filename stopped working
How do I make a field from a tag source
Want to rename song names from text file
Cover Art disppears after Saving Changes
Moving covers to network drive with an action
Genre field not maintained in tag panel
Cover zu Musikstücken länger als 10min
Weird problem tag free files and VLC
Clearing out ID3v1.1 tags
Tag window cannot be filled in
Spaces between letters
Batch Changing Embedded Cover Art
Song Order in a Folder
Importing Multiple Genre Tags Not Working
Playlist ohne oder mit kürzestmöglichem Pfad erstellen
Sort releasedate in the tag panel
Should I use ";" or "\\" or "-" as a separator?
Fix: Genre field within the program
MP3Tag does not recognize Covers and Metadata
Metadata disappearing when cover is added in FLAC
Convert file name to tag
File Corrupted After Editing Tags
Cover export gives a *.bin file?
Unnecessary Warning Stalls Process
Display additional tags on m4a
Changing all files album field to their parent folder's name
MP3 Tag Not Visible in File Explorer in Windows 10
File List columns for extended tags are empty
[Idea] Ignore Errors, bulk skip un-editable files
Umbenennen innerhalb Title (See inside)
Column not showing input
Header parse Error
Renaming from Tags may cause problems on network storage
MOVE files from sub folder into main folder
Datei verschieben führt zu Dateiname .mp3
Delete digits from filename
Absturz nach Konverter / Dateiname-Tag
Populate mp3tag album tag with folders name
Not allow to remove tag
Version 3.17 Dateiname - Tag funktioniert nicht
Genre deleted if any other tag is changed
Tag column not editable
MP3: edit, then save worked as expected - but Properties>details remained unchanged (blank)
Plex Server und Datum
Why is MP3 Tag Replacing Chars
Always Hangs on 6th Tag
Manipulating contents of the 'Artist' Field
GENRE Lost all my user-defined genres
Splitting double/triple etc cds
Neue Spalte Wert: und Feld:
Why I am not seeing my topic I posted today in Support
MP4 Cover Art problems Windows 11 22H2
Fixed song time lengths with iTunes convert, now Album Artworks not showing in Music Player
Listing all subdirectories folders only
Mp4: No longer any tag changes supported
How to rename my folder
Trying to perform a search of my files for a specific word/sequence
$regexp(%TITLE%,[^0-9a-zA-Z],) does not work
Playlist in Unterordnern erstellen
Year tag reformatting with \\ in tag
Cannot edit files
Copy a tag field in other tag field, not working!
No Saved Album Artwork
Having trouble with tags not being applied
MP3Tag no longer in context menu Win11
Copy pasting filename tag
Tag Sources Discogs
MP3TAG messing up with MP3 comments tag when editing
Displaying Track Length in the Tag Panel
Compare 2 different files
Track Listing order
Schreibweise ändern //
Moving files From one folder to another
Display \\ in column browser
Batch convert lyrics to utf-8 encoding
RegEx format help needed
Delete in Title "(Remastered in year xxxx)"
Parsing a portion of current folder name to rename files
Music Filename To TAG Fields Artist & Title
Remove numbers from file and title names
Replace a fixed text string (in File Name) with a variable %year%
Ansicht nur eine Zeile pro Album
Executing multiple operations (tag+file name) after another
Discogs and 1st blank spaces in titles of songs
Downloaded the new MP3tag- NO BOX FOR ALBUM COVERS?
Issues with displaying tags for some high res formats
Cover werden nicht in Traktor angezeigt nachdem sie in MP3 Tag eingefügt wurden
Add Discogs Genre & Styles to Mp3-Genre
An easy way to transfer data?
Custom "sort by" for a field column instead of alphanumeric sorting
Rewritten .m4a metadata, but new tags not being read
Ordner anhand vom Tag "Kommentar" erstellen
Unwanted hyphens at beginning of filenames
Can i not auto tag j-pop songs
URLs in comment field getting duplicated?
Dmp file just before mp3tag crashed
How do you run scripts?
Adding a column and filling it with data
Problems after upgrading to 3.18
Renaming Folders in Explorer
Dateien können nicht geschrieben werden
Adding a cover changes the length in metadata
Need Help about swap field content
Moving files with action
How to avoid Gracenote Recognition
Feld "Jahr" in MP3Tag + iTunes
MP3Tag refuses to tag files
Trouble with cover art in VLC
Tag source lookup not working 12002
MP3 Files anhand von Tags in Ordner sortieren
Lost ability to read basic tags on mp4 between 3.28 et 3.33 version
Tag to File name
All my cover art columns are blank even when they have art
Music files corrupt or unsupported format
Tags Showing Up as Bad
Dateinamen ändern sich beim Laden in MP3Tag
Mp3tag übernimmt eckige klammer nicht
Error encountered when modifying file information
[regex?] How can I remove lines with Chinese characters from the lyrics field?
Transfer settings to new PC
Viewing and exporting Extended Tags
Mp3 flag/bit edit ability
Kommentar und Gruppe wird nicht in Datei übernohmen
Editing file name
Apostrophe vs. Accent aigu
Manually entered tags not in mp3tag
How to batch edit extended tags
Updating tags on multiple files causes MP3TAG to hang
Replace/Delete Function
A tad confused - Windows Explorer does not show contributing artist
Foo_run searches
Zero Numerical Values and can't copy any different information into tag - See Image
Revisiting Remove Track #'s
How to filter songs with japanese characters
Can't open erroneous M4A file for writing
Nicht bei jedem Start Dateien durchsuchen und anzeigen
Concating file A with A, first A is silent
MP4 Tag to Tag Problems copying comment to podcastdesc
Accessing MP3 tags with VB.NET code
FLAC-Kommentar-Tag im Windows Explorer anzeigen geht nicht
Replacing causes case conversion
Tag Help and editing
Publisher & Copyright fields
Pictures are weirdly corrupted after inserting it to files
Error 'Cannot Write File (file path)'
Titel als Kopie des Dateinamens
Cant open file after saving it
Title Name - Features
3.14e 64bit crashes every time I try to add cover art
Crashes and can not be restarted
Track tagging in mp3
Bug or Not bug after conversion flac to mp3 with VLC?
Music Genre Tags Just WILL NOT update!
'Tracknumber' suddenly empty in windows
Total Discs number prefix in filename
Playlist in geändertem Ordner abspeichern
How to manually edit the "original year" field?
Art wont show up on files in finder MAC OS for wav files
How to Add Extension of album files in folder names?
Custom Genre List
Import Cover from File, again
How can I show the "Tags"
Filtern mit Anführungszeichen
Removal \\ from artist tag
Flac files were damaged after MP3 processing and tagging
Dateinamen ergänzen und umbenennen
No place to enter the song title. That entry box is missing
Suche Tool um nachträglich das Jahr zu ermitteln
Bpm in rekordbox ermittelt in mp3tag anzeigen
Completeness (Missing Tags)
Remove numbers or other characters from a field
Searching (filtering) Fields with Multiple Values
Track numbers disappear
Is there a way to write protect the music files in MP3Tag
Removing from the left site
Format Value (Calculation Across Selected Files)
MP3Tag cant' rename Songs to same Name, but they are in different Folders
%_path% not work in TCMD
Bei Titel - Interpret und Titel
Removing parentheses from title and filename
Tag info from _directory
How to unblock "Change Directory" feature
Sorting non standard columns
How Do i tag so that mediaplayer see
Nach Neuinstallation erzeut der Playlist-Generator nur noch Fehlermeldungen
Total time is incorrect
Add genre to existing genres
Filter syntax not evident
Get Full YYYY-MM-DD Into Folder name
How to save album art
Previous metadata tags not changing to new format
Create action to change filename to title field
Regulärer Ausdruck, um Inhalt von Klammern zu löschen
Remove Text in Parentheses from Title
Ignoring characters
MP3Tag in Bold want its NON-Bold
Album Artwork Obfuscation
Album Art Not showing in MP3 Tag since upgrade to Win11
Filter for capitals does not work
Age old Question regarding sorting of mp3's on USB
An action removing everything after a specific character
Wie kann ich erreichen, dass MP3Tag den Ordner umbenennt, statt Dateien zu verschieben?
Cant name some tracks with disk number 1/22 2/22 etc
Would like to know what $1 does?
Artist Edit by removing first few characters
Help with cover art
Mass editing MP3 metadata across many folders
ERROR ID3V2.3 header parse error
I cannot get the action "export cover to file" to work properly
How to automate removing items from artist field
Composer Field Not Uploading Correctly
Conflicting Genre Tag - mp3tag vs. Lumin App
Feature: tag - tag renaming
Discogs Album Artwork Failure
Neue Elemente erzeugen in Tag Panel und Dateiliste direkt aus Erweiterte Tags
Show Complete Album not linking correctly in iOS
New to mp3tag and getting error I don't know how to fix
"Split field by separator" doesn't work using _ALL as field
Trying to save mp3 with cover art but i get error with OneDrive
Non-ascii tag cleanup
Zeichenkette vor Trenner löschen
Metatags for Sonos on Android Devices
Old mp3 with tags in japanese
Trying to combine file name parts to a tag in different order
Vehicle Won't Display TITLE tag after using TAG - TAG
Wie lässt sich ein Cover oder mehr automatisch in den jeweiligen Albumordner runterladen?
Has Quick Actions behaviour changed?
Inserting track numbers into song titles
Saved Changes to a data base
I have one problem MP3 album I bought from Amazon
Audiobookshelf use
One album of flac files won't tag correctly for Windows Explorer
Show different covers for collection music files
Attempting to export a list of mp3 files located in a directory using window 11 and Mp3Tag 3.33
MP3Tag doesn't work reliably on WAV files for me
Getting the date and time out of my steam clips
MP numbering in folders
How to restore missing MEGADATA?
How do i fix "Cannot write file..." error?
How to delete Catalog number from Work
Album art column not displaying
Newbe changing usb playlist
All video cover I was add, is disabled or removed after add title or album
Not all writing to details
Filename in Title field
Replace and Replace regexp actions issues
AWOL albumart - a real pain
Mp3 archive editing
Changing part of filename
The Mp3 Tag won't save any changes
Check title includes mix
Replace multiple genres with one
Need help understanding track #s showing up different in Mp3Tag over Tag&Rename
TAGS not being populated correctly
File explorer and tracks numbers
Renaming audiobook title
Combining Multi Discs Albums Into One Album!
Tagging AAC files
Create an exemption for "Orchestra" in ArtistSort
How do you remove tags of Suno
Lines being blanked and folders being created. What's going on?
ADMPlugin.apl in MP3tag window
Windows explorer Date field does not work after TAG copy/paste
Files and titles are different
How to bulk save images
Not seeing track info using flash drive in 2025 BMW X5
V 3.20 - Filter Field issue
Reformating title, etc
Add the KEY and BPM for a song
Tagging Double CD's or larger
No context menu in Windows 11 under ARM64
Guess value action
Trying to fix track lengths that are incorrect
Cannot write file error
Not allowed to save changes
Problem: Wie entfernt man Klammern?
ISRC field does not populate
Cannot add a new tag to the tag panel
iTunes MP3 Bibliothek bereinigen
Mp3 tags not displaying in Properties/Details of the audio file
Format string - make parentheses into brackets and make text within lower case
Hilfe bei AKTIONEN zum Hinzufügen von Leerzeichen bei Klammern
