After installing 3.19 for Windows, 3.18 was not overwritten
I almost always launch mp3tag via a Windows context menu option. After installing the new release 3.19, I noticed that launching mp3tag via the context menu opened the prior version, 3.18.
Opening mp3tag from the installed desktop shortcut opens 3.19 as expected.
After installing 3.19, I found that I now I have 2 copies of mp3tag.exe.
3.19 C:\Program Files (x86)\Mp3tag\Mp3tag.exe
3.18 C:\Program Files\Mp3tag\Mp3tag.exe
I am sure I can fix my setup, but I assume this is unintended behavior for the installer. When installing 3.19 (and every other prior version) I simply accepted all the installer defaults.
The first one is the 32bit-Version of Mp3tag, the installer is called mp3tagv319setup.exe
The second one is the 64bit-Version of Mp3tag, the installer is called mp3tagv319-x64-setup.exe (or in your case was mp3tagv318-x64-setup.exe)
Could it be that you mixed them?
You can have a look in your (windows) control panel for installed software. I assume you will see two different entries?
Definitely.
No, there is only one entry as they share the same name.
See also here:
Yep, that was it. What a dumb mistake, haha. Sorry for the false alarm!
