Hi wen i wand to change manually a item in tags i can type for example 10 by track.
But by enter the old text is there its not changed to what i typed
i can non of my directorys change the tags. I downloaded a music file about 1 hour ago and can't change the tag.
Not with the older version of mp3 tags also
I works out of the box before i reinstalled windows
I try with a total other program and that works out of the box
OK, so it's not a problem related to the update to Mp3tag v3.33.1, but more related to either updating Windows (less likely) or the downloaded file having problems (more likely).
If you're interested, see MP3 Diags from How to check files for errors? and check the file for issues.
It's possible that this other problem ignores potential issues with the file.
i fond the problem it was a setting in option by mpeg id3v2 whas cheked out
Excellent! Glad you found a solution to this problem ![]()
