How to check files for errors?
It’s required and often helps to reduce support cycles to check files for errors before filing a bug report.
Symptoms of erroneous files are often
  • missing or wrong bitrate or length
  • audible blips or skips
  • tags seem to be sticky and cannot be removed
There are some really good tools to check the files for errors, namely
MP3 Diags — identifies many different issues in MP3 files
Website: http://mp3diags.sourceforge.net
Download: MP3 Diags - Getting MP3 Diags
If the font size in MP3 Diags is too small to read, try the Tutorial on how to set a larger font size in MP3 Diags .
MP3val — validate and fix MPEG audio files
http://mp3val.sourceforge.net
foobar2000 — multiple supported formats
https://foobar2000.org
After installing foobar2000 see Utilities → Verify integrity from the right-click context menu to check the file for errors. In case of an erroneous MP3 header, Fix VBR MP3 header might even repair the file
Note: In many cases the troublesome file may play correctly in some or all media players or may be editable in other metadata editors. However, this is not an indicator of whether the file structure is valid or not. In contrast to just playing a file, Mp3tag re-writes the metadata part of files and takes a cautionary approach when performing changes that might affect the audio part to prevent data loss or more damage.
Impossible to edit certain tags in files
Error: MP3 header parse error
ID3v2: !BAD
File cannot be opened for writing. (exported from Vegas Pro 15)
MP3 reports cannot open file for writing
mp3-Files - Zeitmarken?
Custom tag "Traktor4"...?
MP3 Tag only working on some mp3 files, not all
User-defined Tools
Different Bitrate value between mp3tag and windows explorer
Mp3 files can't be opened anymore after editing some tags
Cover wird nicht angezeigt
Adding Cover Problem
Copying MP3 files to device
Tag window cannot be filled in
Feature request: action to rewrite tags from scratch
Sometimes Mptag doesn't show correct 'cover varies' message
Issue with Text file->Tag
MP3 not responding
MP4 file Tag editing not working
Ver 3.14 bug: file "cannot be opened for writing"
Foobar2000 and Mp3tag present different metadata contents
Tag Content Group not editable?
Missing Tags in some MP3 files
After search & replace mp3tag didn't respond
V2.95 - Export Cover via Right-click from Edit Panel - .* is the only file extension available
Error "updating" tags
Incorrect file length
MP3Tag does not recognize Covers and Metadata
"Remove tag" as an Action
Album Art Not Appearing
Genre tag field updating but updates not displayed
Not allowed character in track tags, inside playlist
Chinese characters show in player but not mp3tag
Adding a cover may change the length
MP3 ERROR with loss of images
"File Cannot Be Opened For Writing"
Unable to add cover art
Länge der Mp3 wird nicht angezeigt
MPEG 1 Layer III Information falsch
About the Bug Reports category
3.14 portable mode crash on Win 10 on add art to mp3
Corrupt file headers/tags in MP3 files
Tags (inkl. Cover) werden in app nicht aktualisiert angezeigt
Frage wegen Cover Anzeige
Albumsortierung auf Sony NW-A45
Checking further because the ID3 Tag ends at
Why can't MP3Tag see some files cover/art?
How can I select ID3V2.3 and UTF8
MP3Tag (egal welche Version) tagged immer nur 6 MP3 Lieder
Crash when saving Extended tag edits of flac file
Wie erzeugt man Album cover mit mp3tag?
Using MP3TAG with conditional logic - Windows 10
"Self-deleted" tag and mapping panel
Album-Name verändern (über 100 Titel)
Not all tags are removed
Can't convert tags for song
Need help with Filename - Filename
I cant add comment tag
I have an album cover that doesn't show up in VLC but other album covers do
The export tags feature fails for 55k files
Changing Tags corrupts file in Windows Explorer/Media Player
Album names showing up in Chinese or?
Adding lyrics not working
Cannot tag m4b file
Keine Anzeige von Tags im MP3 Player
Some MP4 files are not listed when starting from context menu
How to fix ERROR: MP3 header parse error
Paste error, cannot open file for writing
Edits done to one specific file don't reflect in Properties
Adding album art corrupts music file in 10a
Cannot play mp3 file if it includes tags
Song titles with special characters change when importing to Itunes
Mpeg-4 AAC Tags Cannot Be Edited
Issues with displaying tags for some high res formats
MP3 Tag is stripping Metadata from the Tracks
How to Remove Lyrics data showing. Please Help
Saved my Tags but they are not showing in Windows file details
Not allow to remove tag
Mp3Tag Corrupts my MP3 files after editing
Missing Covers in some files
Mp3tag goes to "not responding" after several dozen manual edits and saves, thus locking up and crashing Windows 10 Pro 64bit
Can't save changes
When I tag mp3 files, Windows Media Player stops working
Windows 11 - tags written but not visible in Explorer
Why are files show up with X and missing bitrate/length
Genre tags hang around
Windows Explorer does not show tag data
Cover Art disappearing
MP3TAG erases tags while doing group tag editing
Freezing when trying to get album art
Cannot be opened for writing - Yet again
Mp4: No longer any tag changes supported
Hints for asking Support Requests
MP3Tag does not see file tags?
DisCoverArt: Batch import album cover art based on artist and title
"!BAD ID3v2" - how to restore the tag information?
Length Field display
Unable to save cover art
Problems with Chinese characters
Compare 2 different files
Unbespielbarkeit
Tagging compilations
MP3TAG messing up with MP3 comments tag when editing
Specific MP4 file cannot be opened for writing
Can't access MP4 files
How to find cause of !Bad Id3v2 errors
How to find/enter missing metatag values
How to enter missing bitrate and length
App hanging on writing tag data
Bekomme Fehlermeldungen
File “cannot be opened for writing”
Display LENGTH in column
Show raw tag data in Extended Fields [Request]
Tool to delete tags and add them back
Mp3 file does not have a Comments field; it is not modifiable in mp3Tag, either
Mp3tag VIA BSI Info Editor (BSI Simian)
Programm friert ein
Music files corrupt or unsupported format
Dateinamen ändern sich beim Laden in MP3Tag
Missing Basic Tag Data + Error
How to fix mass of mp3 wrong times? after editing 50000 songs, times all wrong
Plötzlich Tag-Fehler
Mp3 file won't play
Only filename appears on my portable mp3 player
!Bad ID3V2 on only one of a two disc album?
MP3-Newby has non-playing albums
Removed or updated Album Covers are still displayed in VLC and Windows
Cover art seems to be missing
Error 'Cannot Write File (file path)'
Replace artwork with artist name?
Album Cover wird nicht entfernt in Windows
Tags not recognized by Windows Media Player
Length (duration) calculation for MP4 files
Cancel reading files does not stop immediately
Wavepurity seems to not support PNG cover art in APEv2 tags
Bug or Not bug after conversion flac to mp3 with VLC?
Pasting MP3 tag to MP4 file - Year gets 2 slashes
Create a Playlist problem with newline characters
LAME and unwanted ReplayGain fields
Changing and saving MP3 meta while playing
Cannot add tag info into large wav files
Folder art troubles *solved*
Unable to read some .mkv files using IDM
Field turns white in File List upon click and application freezes
Help sourcing an issue preventing my library from loading
Änderungen Name, Genre etc
After up date to V3.33.1 problem with mual add tag
Song cover not showing
Mp3 tags from files to mysql database
Replace "The" in filename does not work
Adding "Composer" changes file duration
I can't edit song track length
Is there a way to remove silence at the end of files
Having issues with Filter/Search
Not assigning tags to respective columns in Windows Explorer
Unterschiedliche Längenangaben von MP3s (Windows 10)
Difference between Discogs' timestamp and actual file duration of track
Error in files Tag
MP3 damaged or Mp3Tag missing something?
Feature suggestion: tag checking/validation
Mehere Lieder werden mit einem roten X angezeigt
Old ipod not compatible with car media player says no playable files
Boss Elite 550 Incorrectly reading Tags
Potential Tag Corruption
Auto-numbering wizard fails to renumber
ERROR ID3V2.3 header parse error
Some files show incorrect (or no) time in Length field
Can Actions be executed by Tools?
Cover art is not displaying on my desktop
Cannot write file
Renaming tags fails - program freezes
3.15 can't drop & drag album art
How do I copy CODEC and BIT RATE info
Red "X" and Plex
Albums Not Showing In Main Folder
Coverart Issue For Car Audio Player
Can I search regular expression with searchbar from this forum?
Why am having on the tab TAG this message: MP3 header parse error
Tag-Panel lässt sich nicht mehr integrieren
Saving changes in flac files songs don't play
Wrong Codec / Mode detection?
Tags visible in file explorer are not visible in mp3tag
Wrong time lenght
Tags For Mp3 in current version compared to version 2.69
Trying to fix track lengths that are incorrect
How do I remove the red X on the left side of Filename for some of my song names
So in mp3tag my it won't let me save the file cause i used YTMP3 but ion know what to do
Windows Media Player cannot play an M4A file after editing the Album field in Mp3tag v3.35
Mystery "No Album Info" files
Mp3 Tag says file has no values
Inserting Lyrics using MP3 Tag
Cannot write file error
Albums Covers Are Not Being Saved
Edited tags appear only within the MP3Tag app
Mp3Tag Does not recognize Bitrate
ID Tag abändern - dumme frage
Help with tags on budget mp3 player AGPtek A19X
Mp3Tag erzeugt Last beim umbenennen und hängt
Google Play Music not recognizing embedded cover art
Is there a glitch in the Feb update?
Keine Längenangaben bei einigen Tracks
Can't listen to audio after adding tag
Hidden and conflicting tags in MP3 files
Cover zu Musikstücken länger als 10min
Mp3tag Not Able to Access Track
I can't give multiple mp3s in the same album both cover art
How to repair files identified as corrupted?
If the file in question is a MP3 file which is reported as corrupted or where the MP3 header cannot be read, chances are it is an MP4 file with a *.mp3 file extension. This often happens if online services, e.g., to download files from YouTube are involved. Changing the file extension to *.mp4 might solve the problem.
If the problematic file is a WAV or AIF file, re-saving the file with an audio-editing program like Audacity might repair the files. It's also possible to use ffmpeg via a user-defined tool from within Mp3tag
Please also listen to the end of the file to make sure the file isn’t truncated.
